Spacers on rear drum brakes
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
From what I can gather, the drum assembly is about 0.125" shorter on each side than the disk assy. My '89 Formula had them. And they should be on both sides.
Bob
Bob
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I think only the iron-drum'd brakes got the spacers. I have the aluminum drums and don't have the spacers, nor did others with them. I think the aluminum drums were a little wider than the iron drums, so the spacers weren't needed. Either that, and/or GM wanted to put something between the aluminum wheels and iron drums to prevent galvanic corrosion (wouldn't happen between aluminum wheels/drums)...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
AkDrifted
Aug 17, 2015 07:45 PM
