Squawking noise from sway bar bushings.
Old Oct 17, 2000 | 02:09 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Now that the weather has turned colder here in MN i have noise coming from the sway bar bushings. Anyone have a fix ??
-Auggie-
Old Oct 18, 2000 | 08:03 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Unbolt the sway bar mounts (you can leave the endlinks attached), remove bushings from the bar, grease inside of bushings, reinstall bushings and mounts. I had to do the same thing last year since mine were also sqeaking. Problem solved.
Greg Westphal
'87 IROC 305TPI/A4
Old Oct 18, 2000 | 09:20 AM
Auggie's Avatar
Thanks Greg and what kind of grease did you use?? I know that i heard there was a redesinged bushing but i just can't put my finger on it. I'll keep trying and let you know what i can find out.
-Auggie-
Old Oct 18, 2000 | 09:46 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
You might want to consider putting greasable bushings on your swaybar. Taking them off surely isn't alot of work, but if you have the others, whenever you do a lube job, you can do them at the same time, or more often, if needed. When I replaced ALL my bushings a few months ago, I put those on (put them on the rear swaybar, too). You can get 'em from Summit or some other places, as well. Mine are the E/S poly's - cost about $14 a set.
Old Oct 18, 2000 | 11:43 AM
Engine: 385 HSR
I think I used the Mobil synthetic grease that I use for my other suspension part grease fittings. Several months ago, I tried finding part numbers for the ES greasable bushings, but they didn't have them listed for my sway bar sizes (34/24mm). :/
Greg Westphal
'87 IROC 305TPI/A4
Old Oct 18, 2000 | 10:43 PM
Auggie's Avatar
Thanks guys,
-Auggie-
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
