Vaccum Line on brake pedal switch
From: Coulterville, IL...Currently on Beale AFB, CA
there is a vaccum line that runs from the plunger (??) under hood to my brake pedal switch. Can I remove this assembly? I am taking out everything I do not need b/c this is a street driven race car.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
It is for your cruise control.
James
If the women don't find you handsome they should at least find you handy
James
Car: / 89 IROC /
This switch also operates the lock up on your torque converter if you have an automatic.
Viking
89 IROC original owner, 3 amplifier 8 speaker Kenwood/Infinity sound system, 300,000 miles on original 305 TPI. Change your oil!!!
http://members.bellatlantic.net/~viking88/iroc.html
Viking
Car: 82 camaro SC
It's a safety for the cruise control. The cruise control should turn off when the brake is tapped electrically, from the same switch that controls your brake lights. If for some reason that didn't shut down the cruise control(brake light switch broke), the vacuum switch will take vacuum from the cruise control unit to release tension on the throttle when the brake pedal is held down. Once you slow to about 30, the cruise will kick off.
1992 Trans Am
May 10, 2023 07:19 PM
