Plz read ---->Brakes: odd clicking sound when coming stop after brake job
Old Oct 19, 2000 | 01:42 AM
Highwind's Avatar
Car: 1988 Firebird
Engine: 305 TBI
First of all this is what I did:
-turned one rotor(left)and replaced the other(right)
-repacked old set(left)of bearings and new set(right)
-replaced both calipers with remanufactured ones.
-installed new pads (Raybestos)and bled the brakes.
About 1-2 weeks after the brake job they started to squeal (both sides). Also, normally when it's cold and I come to a stop I begin to here from the front left side a sound like click-ah-click-ah-click and I can feel a slight pulse in the brake pedal at the "click" sound. Can anyone give me any ideas what may be causing this and guess what i may have done wrong when doing the brake job? Thanks.
Shouldn't bother putting this but hey what the heck:
1988 Maui Blue Firebird 305 TBI stock (WITH NEW PAINT!! YAY! )
Old Oct 19, 2000 | 10:50 PM
90FFBird's Avatar
The pads (154?) should have tabs on the outer pads. These tabs need to be pinched down on the caliper to anchor them. If you don't you will get that clicking sound as the pads move around. Did you check the new rotor for truness before it was installed? If not, it could have a slight warp that can also cause/aggrivate the clicking noise. I'd make sure the pads are anchored first and see what it does. If it doesn't cure it you may have to turn the rotor. Good luck, Rob.
Old Oct 20, 2000 | 09:33 AM
Highwind's Avatar
Car: 1988 Firebird
Engine: 305 TBI
Thanks Rob, but the sound is coming from the resurfaced old rotor (front left) and unfortunately i didnt recheck the trueness. But Ill check that tab thing. Do i just pinch them down with pliers if they arent hugging tight enough? Ill be able to check them out this weekend. Thanks again.
[This message has been edited by Highwind (edited October 20, 2000).]
Ghettobird52
Jul 5, 2024 11:18 PM
Jae992
Aug 27, 2015 09:07 AM
B_Dubya
Aug 26, 2015 05:09 PM
db057
Aug 22, 2015 08:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
