brake fluid leaking..
Old Oct 25, 2000 | 03:01 PM
badbird88's Avatar
What causes the brake fluid to leak from the resivor? Do the seals need replacing under he tank itself or just the lid? Are they special seals or can they be picked up from any parts store? This fluid has ate my paint off and caused my fuel lines to form rust on them and I need this fixed fast. Thanks!
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Oct 25, 2000 | 06:56 PM
CamaroMike's Avatar
NEW MASTER CYLINDER WITH CAP! FAST! Brake fulid is one of the most corrosive fluids in a car!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified CHEVY DEALER Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Oct 26, 2000 | 03:46 PM
badbird88's Avatar
tell me about it, it stopped for a while then the next thing I know my paint is bubbling and the fuel lines were rusted in some spots!
I have a master cylinder off of a 89 IROC with the rear-disc brakes that is in good condition...will this work with my drum brake rear or will the proportioning pressures screw up the way the brakes should stop? If not any recommendations on a master cylinder to replace mine with or jus tbuy a new one from a local parts store?
Thanks!
Old Oct 26, 2000 | 04:53 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
If you have drum brakes the master cylinders are the same, the 88 and older rear disc used a diffrent master.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
masonta
Sep 1, 2015 06:40 PM
