Spohn Torque arm mounting questions
Old Apr 4, 2010 | 09:22 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi
I currently have a adjust Torque arm from Spohn on my car. I'm in the middle of swapping in a 4L80 tranny in the car and I need to make a new crossmember with a new torque arm mounting.
I can do a similar setup as the spohn but then I need to modify my Y-pipe. And I wonder how it would be if I the torque arm is bolted in the crossmember, with NO ability to move (forward/backwords) like the spohn crossmember allows it to.
Maybe just weld two "ears" on the crossmember and bolt it through them? In that case the holes could be made slotted and then allow it to move forward/backword some?....
Good/bad?
/N.
Old Apr 4, 2010 | 11:38 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spohn Torque arm mounting questions
the arm has to move forward and back. a rigid mount will bend/break
Old Apr 4, 2010 | 12:11 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Yeah, I thought of that, so a couple of ears with slotted hole should work then....
/N.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
