Strut Removal----Coil Springs
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
OK I am getting ready to replace my front struts now that I have redone the entire rear suspension(thanks STEVE SPOHN) I keep seeing that people say that you have to compress the coil spring. Why is this??? It does not seem close to the strut....... I NEED HELP...
Brian Felts
Brian Felts
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I didnt have to, alls I did was jack the car up with a floor jack and then set it back down on jack stands. I placed the jack stands right under the control arm,(outer lip, towards the tires)and that was it. There was nothing to man. I just did mine yesterday. Look for my post about changing struts....the guys helped out alot....
Really theres nothing to it...
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Performance Resource Chip
Flowmaster Muffler
Throttle Body Coolant bypass
TPIS air Foil
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
AC Delco Rapidfire plugs
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Flowmaster Muffler
TPIS air Foil
K&N's
Gutted air box
Moroso Super Coil
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
There is no need to compress the springs at all. The key thing is to support your control arm while removing the strut because that's the only thing that's going to hold that arm up, which holds your spring. Just put a jack under it and raise it enough to lift the arm and take the pressure off the strut so you can remove it. You do not have to remove your rotors, either. If you need step-by-step, let me know - glad to help.
KAM
KAM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Dragonsys
Sep 25, 2015 03:51 PM
