9 bolt conversion, NEED HELP!!
Old Nov 8, 2000 | 03:38 PM
Blown355Camaro's Avatar
I put in a 9 bolt rearend and i switched to 4 wheel disc breaks, i got the rearend with nothing on it (it calipers pads lines..) And i went to Autozone and got some new calipers and pads. I had a Break line to screw into the calipers and when id screw the line into the caliper itd never catch itd still spin and it would still drip fluid onto the ground. Someone told me that i need to get a "banjo nut" to screw into the caliper and then i screw the break line into the banjo nut which is screwed into the caliper. Anyone have any idea what im talking about, if so where the hall can i find this "banjo nut" at??
Thanks guys!!
H00SiER DADDY
Supercharged 1985 Camaro TH350 9 bolt 3.23
1986 351 C4 Ford 9" Mustang Coupe
Old Nov 8, 2000 | 04:24 PM
ede's Avatar
ede
i believe you need what they call european brake lines. the nuts have a unthreaded part that makes it longer and makes the seal differant.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 8, 2000 | 10:34 PM
84IROC's Avatar
Go to the wrecking yard and get the correct brake lines off another F-body or or do a little trial and era in the wrecking yard to see what else you find to work in its place. I do this all the time with various parts in the wrecking yard. By the way, when I got my Disc brake rear axle out of the wrecking yard I took all the lines all the way to the proportioning valve and I also snagged the entire rear suspension. I just piled it all up and had the fork lift driver load it all up as one peice and I then went in and paid for the "rear axle" he-he.
If you still want to adapt the lines you have now you can probably find the adapter you need at a supply store that deals in these types of brake-lines and fittings. One other option is to have the lines made by any of the many advertisers, in all the car mags, that specialize in this type of tubing.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Nov 10, 2000 | 09:56 PM
farm-kid/88camaro's Avatar
it would probably be a good idea to get new lines, since your old ones are probably all corroded. Ede was right, you need the european type lines, your autoparts store should have them
Old Nov 20, 2000 | 08:03 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I just had the same swap and my problem was the calipers have a metric thread and the car has a standard thread. I got some adapters and ran new lines. Easy fix. Works great.
Old Nov 20, 2000 | 10:04 AM
amagin86's Avatar
stinger,
where might one find these adapters, at the parts store? i'm going to put a 9bolt in my 83 and can see this may be a problem.
thanks
Old Nov 20, 2000 | 10:21 PM
merf23's Avatar
I have a metric rear and an SAE car. When i did the swap, i just re-flared the lines where they connect to the rubber hose with SAE fittings. All you need is a flare kit and the fittings (both are inexpensive).
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
