How does torque arm length effect the feel of the car?
Old Apr 10, 2010 | 09:42 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I had the Spohn setup on my car. It was the trans crossmember and crossmember mounted torque arm for the TH350. I'm building a new crossmember for the T56 thats going in now. I realized that to have the torque arm mount in the same place as with the Spohn crossmember is not possible while having a double hump crossmember for exhaust clearance. So I was going to make a mount out of box tubing going from one subframe connector to the other subframe connector and attach the torque arm this way. This plan is not set in stone as of now though. I did some quick lining up and it looks like I will still have room for my exhaust the way I want to run it. The exhaust would actually sit above this bar. But I need to do some more precise measuring to make sure I can get the pinion angle I want with the bar here.
My main question though is compared to the length of the torque arm as it comes from Spohn, how will the car feel if I cut about 5" out of the arm? I was going to cut the 5" or so out of the back. I was just going to buy new tubing adapters and weld them in.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
gwade12
Aug 8, 2015 08:17 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
