Best first upgrade?
Old Nov 28, 2000 | 03:48 PM
Josh 91RS's Avatar
Best first upgrade?
I have a 91 RS. I want to make the handling a little bit better but dont want to spend a ton of money just yet. What will give me the most performance for a cheap price? Should i go with The iroc sway bars and wonder bar? That should only be like 25 bucks from a JY right? How about bushings? How much do those run and how much of a difference will they make? Anything else i can do for cheap? How about cutting the springs?
Old Nov 28, 2000 | 04:22 PM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Hi,
The absolute first thing that you should do
is to get a good pair of sub-frame connectors. This will make your car "whole".
Then think about a strut tower brace...then
lowering springs/shocks..then all the other
crap.
Mr. IROC-Z
Old Nov 28, 2000 | 04:57 PM
Josh 91RS's Avatar
How much do some sub frame connectors run? Installation easy for a beginner or would i have to take it to a shop? What are some good brands? Thanks a lot for the help
Old Nov 28, 2000 | 08:48 PM
82camaro's Avatar
Car: 82 camaro SC
Lots of good brands of SFC's. I built mine, so I don't have an opinion on the brand. Have a shop install them. They need to be welded to work right.
poly bushings
aftermarket sway bars(or big stock bars)
drop springs(reasonable prices for a third-gen
etc...
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Nov 28, 2000 | 11:13 PM
Mr. IROC-Z's Avatar
Hi,
You want to get sub frame connectors, that are weld on....do not get the bolt in type.
My Sub-Frames are from "MAC". They work great and they are cheap...they are about $99. Look in the Super Chevy Magazine and they should have an ad there.
Old Nov 29, 2000 | 10:45 AM
Josh 91RS's Avatar
How much can you notice the handling difference after the sfc install?? How about bushings, any good brands for those?
Old Nov 29, 2000 | 01:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Josh, by throwing on polyurethane end-links for my anti-sway bars, the car improved a few notches on the "cool!" scale. I bought the Energy Suspension ones, I think I paid $20/set (two links, for one bar). You need links with a "2 5/8 inch sleeve length". Summit Racing should have 'em. You'd buy one set for the front bar and one for the rear.
Poly anti-sway-bar mounting bushings are supposed to make your stock bar act as if it's one size larger. For those, you have to measure the diameter of your anti-sway bar. Use calipers, or tighten down an open-ended-adjustable wrench on the bar and measure the gap between the jaws. I'm not sure how much those run. Call Summit Racing at 1-800-230-3030 for part info & pricing...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
