aluminuim brake drums
Old Nov 26, 2000 | 07:08 PM
Z28DJP1987's Avatar
Can I replace the cast iron rear brake drums on my 1987 IROC with aluminuim drums? If so where are they availble and at what cost?
Is this a good swap?
Old Nov 26, 2000 | 07:28 PM
ede's Avatar
ede
yeah you can, look in junk yards at caprices, malibous, impalas from later 70s early 80s. not sure if any thirdgens came with them or not or if you can buy replacements. it'll save rotating weight. it's a good cheap and easy mod.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 26, 2000 | 07:41 PM
jmon92conv's Avatar
Napa and pepboys sells them about $60 a set. They caame on 84-86? At least that is the years I used to check for the parts.
Jeremy
92 Z conv
5-spd B&M
alston SFC, few mods, some free, some not
Old Nov 27, 2000 | 09:50 AM
merf23's Avatar
the caprices have a 5x5 bolt pattern, the others are OK. My 84 L69 came with them.
Old Nov 27, 2000 | 08:14 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
mY 86 HAD A SET, I swapped in a disc rear and I still have the drums if you are intrested.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 28, 2000 | 10:57 AM
Z28DJP1987's Avatar
TO BLACK Z
What the price of the alum rear brake drums and what condition are they in??
Old Nov 30, 2000 | 02:09 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
While your doing the swap, might be a good time to put on some new brake shoes
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
