best brake upgrade for the $$$
Old Nov 26, 2000 | 03:46 AM
Dan91Z28's Avatar
I need some new brakes pronto, so i decided to upgrade the rotors and calipers while i'm at it. Baer's are the accepted megabuck upgrade but i can't afford that much. Anybody try http://www.gtrotors.com/products.html#bigbrake or anything reasonably priced other than stock? I'm just driving on the street now but its always a good idea to get the best you can afford i've found. Any tips or recommendations would be greatly appreciated!.
Dan91Z28.
Old Nov 26, 2000 | 11:42 AM
Jason M 91Z's Avatar
Stock size rotors and the single piston cast calipers just aren't enough for these heavy cars. If you plan on doing any serious braking they just won't cut it. I'm doing a 1LE conversion right now, 12" rotors and twin piston PBR aluminum calipers. In retrospect, I may have gone with a Baer kit for $400 more. No tracking down parts hoping it will work, and no other BS like that.
Now I know people are gonna say, "C'mon Jay, not everyone can afford to spend all kinds of money on brakes..." Ok, now think about it. Ever driven a C4 Corvette? They're lighter than thirdgens yet have bigger brakes. Why? Is it overkill? NO! Don't you like pressing on the pedal and being able to come close to lockup without worrying if you're gonna be able to stop? IMHO, if you're going to make your car fast, theres no excuse not to have good brakes so it can stop fast too.
-Jason M. 1991 Camaro Z28
"Shampoo is better, I go on first and clean the hair."
Old Nov 26, 2000 | 12:19 PM
jmon92conv's Avatar
I just bought EBC kevlar pads and slotted rotors for my car with shipping it was 210 total www.openroadint.com 1-877-673-6960 I talked to a guy named Lee, real helpful. I have noticed a BIG difference and for the money it can't be beat
Jeremy
92 Z conv
5-spd B&M
alston SFC, few mods, some free, some not
Old Nov 30, 2000 | 11:56 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Stainless Steel Brakes sells an 1LE upgrade kit for our cars which came with the regular front disc brakes for about $989.
I just received my upgrade kit from SS Brakes last Monday. I probably wont install em until March.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Billy Decker
Sep 4, 2015 03:46 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
