rear coil-overs?
Old Dec 1, 2000 | 02:13 AM
812MANY's Avatar
rear coil-overs?
I'm trying (planning) to put an 8.8" in my Camaro (hey, it was free) and I figured if I can run coil-overs it would be 2 fewer brackets I'll have to weld on (no spring perches).
Does anyone make "bolt-in" kits for 3rd gens?
I was thinking about buying a lower mount kit and making my own upper mount adapter (that bolts directly into the stock location on the body) but I'm woried about cracking the body/frame from having ALL the pressure on that thin sheet metal.
Any ideas?
Yes, I know about the torque arm mount! ;>
I'd run a 9", but I'm on a tight budget and my buddy says an 8.8" with c-clip eliminators and good axles is plenty for what I want to do.
Thanks in advance,
John
Old Dec 1, 2000 | 03:19 PM
JeffT's Avatar
Car: 1991 Z28
check out www.ground-control.com. Goto catalogue then camaro/firebird and scroll down.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
