Koni or Bilstein?
Old Dec 7, 2000 | 09:19 PM
Mark 89Formula's Avatar
Koni or Bilstein?
Lots of people have an opinion. If you have run one brand or the other I'd like your comments. The usage will be 95% street with an emphasis on cornering and 5% drag racing. I'm running the stock WS-6 springs, Spohn torque arm, poly/spherical LCAs, and relocation brackets, stock 36mm/24mm sway bars in fresh urethane, GW subs, TS-14 steering brace, and Del-A-Lum front control arm bushings.
I'm leaning towards the Koni's for the easy adjustability up front. I like the HALs in the rear but am having a hard time talking myself into shelling out $150 per shock. Any feedback from current users appreciated.
89 Formula 350, Accel Tri-Ys, 3" SLP, chip, Jacobs, SLP cold air, Probuilt tranny, Vigilante, 3.27s, Spohn torque arm & LCAs w/brackets, GW Subs
Old Dec 7, 2000 | 10:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Bilsteins came stock on IROCs, so they are a good shock. If you have the money, get Konis. Check out the GP section at www.ws6.com for good prices.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Ed1LE
Sep 30, 2018 09:14 AM
Antips16
Oct 30, 2015 06:42 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
