when is it necessary to replace the power brake booster and master cylinder??
Old Dec 8, 2000 | 06:42 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I'm doing my brakes tomorrow. I am not sure whats neccessary to restore maximum braking abillities,(not that '84 4WDisk TAs have good brakes to begin with). the rear brakes are new,the fronts may need service,I'm replacing all the rubber hoses.it's probably a good idea to replace the master cylinder,but I'm not sure if I need to replace the vaccume booster. has anyone got their disc brakes to work ok?
Old Dec 9, 2000 | 11:04 AM
ede's Avatar
ede
i'd change them when they break, not before. if you're looking to restore 100% capacity then it maybe something to look at. i wouldn't worry about it, unless there is a problem. you can get an idea how good they work by the fluid preasure when you bleed the brakes. if you have low preasure look at the master cylinder and blockage in the lines.
ICON Motorsports
1st & 3rd
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
