Can someone plz. look up these numbers for gearboxes?
Old Dec 9, 2000 | 06:47 AM
Jza's Avatar
Jza
If someone has the necessary books, can you look up a couple numbers off of a pair of steering gear boxes?
Ideally, I'd like to find out the steering ratios. Lock-to-lock doesn't tell me what I want to know and I can't manually count the ratio (or can I?)
The first one is 7826692 and the side next to the pitman arm has a stylized "S" in a box on it.
& the second is 36600525 and has a big ol' "2" in the same place.
Those numbers were taken from right next to the cover plate and if they're the wrong numbers needed, just say which and I can put them up.
Old Dec 10, 2000 | 10:24 AM
OLDYELLR's Avatar
Car: '85 IROC
That looks like the standard Z28 steering box with 2.5 turns lock-to-lock. That's the number on the one I took out of my '83 Z28. The high performance one (IROC etc.) has 2.25 turns. The ratio does not make a whole lot of difference, but the quicker one has a better "feel". You should be able to tell the differnce by counting turns of the steering wheel. If you are looking for one in a junkyard, you want one from a 85-92 F-Body with 16" wheels. Count the turns to be sure.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Dec 10, 2000 | 05:09 PM
Jza's Avatar
Jza
Thanks, but about one day too late..
I already put it in and you're right, it was the 2.5 lock-to-lock. Not what I was looking for, but a nice improvement from what was in there. And since it was free, no complaints.
It came out of an 85 Z-28 Pace Car which must have been one badass car in its day.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
AUZ28
Oct 3, 2015 06:28 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
