Springs that don't lower it
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
I have a 1985 Z28 and I don't really want to lower my car, but I want to get new springs. Right now I can feel every bump in the road, replacing the struts helped alot..I know, I know I need to replace the shocks too, I just don't have time. When I find springs, I will also replace the shocks, LCA's, panhard rod, and get subframes and a STB.
I was just reading a post from Steve Spohn saying that you need LCA relocation brackets that weld in, that's another reason I don't want to lower, another is that I live on dirt/gravel roads, my mom has chrushed the JEEP twice because of big rocks. I have also heard of cooling problems and scraping.
I just want new springs that don't lower my car. Where can you get new springs that don't lower your car for a decent price anyway. All that I have EVER found is lowering springs.
Any help would be greatly appriciated.
Thanks,
Jesse
85 Z28, 305 TPI A4
pretty stock with MSD and a few other toys
15.2@91mph
http://photos.yahoo.com/j_hougnon
Thanks,
Jesse
85 Z28, 305 TPI A4
15.2@91mph
Use stock 90 Iroc convertible springs if you want handling. 707lb/in that's what I run. In the rear I use 160lb/in springs from a citation. Yess they fit.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Car: 85 Z28
do you get the springs from a dealer or what?
Thanks,
Jesse
Thanks,
Jesse
I got them from CarQuest/Napa. Just ask to see their spring book and look at all the applications for Camaro's. Get the lb/in you want from there.
Metco lower control arms come with the lowering bracket that bolt in , I have the Eibach pro kit it dropped the car about an inch , i didnt have anyproblems , and with my 17" wheels on there now the car went back up , but the wheels filled the wheel well which is what i really wanted anyways. so if you plan on going with 17" wheels get the eibach springs
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Eibach Pro-Kit Springs
SLP exhuast
SLP Cold Air Induction
CatCo Hi Flo Cats
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
SLP exhuast
CatCo Hi Flo Cats
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Look no further.
Contact Global West. These guys make high quality $hit. You can order regular springs
from there and even specify how tight you want them.
Tommy
Tommy
Car: 85 Z28
I was thinking, since IROC's had a .5 inch drop compared to Z28's could I get IROC springs and not have to worry about changing or modifying anything?
What type of spring rate would I look for anyway?
ambainb
Apr 25, 2016 09:21 PM
sailtexas186548
Aug 26, 2015 03:32 PM
