1le brakes question
Old Dec 12, 2000 | 10:19 AM
Pino91Formula's Avatar
1le brakes question
Im thinking about upgrading to the 1le brakes , but i had one question, im running ws6 17" wheels with the wheel adapters, and im trying to find wether the 1le system chages the back spacing at all, just because i dont want to buy new spacers?
Pino
91'Formula
LB9 305 TPI 5-speed
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
Old Dec 12, 2000 | 02:45 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I don't think it does, or at least I didn't notice any change when I upgraded to the 1LE brakes on my IROC. If it did change, it wasn't enough to make any difference wrt tire clearance in the wheelwells.
Greg Westphal
'87 IROC 305TPI/A4
Old Dec 12, 2000 | 03:51 PM
Jason M 91Z's Avatar
IIRC, the 1LE rotor hat is 1/2" thicker than the stock rotor, which would move the wheel outward 1/2". HTH
-Jason M. 1991 Camaro Z28
"Shampoo is better, I go on first and clean the hair."
Old Dec 13, 2000 | 03:04 PM
Is that with the 1le spindles or modified spindles?
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Eibach Pro-Kit Springs
Hotchkiss STB
SLP exhuast
SLP Cold Air Induction
CatCo Hi Flo Cats
Old Dec 13, 2000 | 04:01 PM
1LE spindles are modified stock spindles. There is no difference in the spindle dimensions except for the caliper mounting provisions. The 1LE rotor however is much bigger, both in diameter and in thickness of the rotor hat and friction surface. The 1/2" thicker rotor hat makes the wheel stick out further by 1/2".
Old Dec 14, 2000 | 10:52 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
The wheel mounting face on the rotor is in the same place on both regular and 1-LE rotors. There is no change in offset. I have measured.
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
