subframe connectors
Old Apr 21, 2010 | 08:28 PM
dkrider24's Avatar
subframe connectors
whats the best subframe connectors for my 86 t.a? wantin to build a mild race/ street car. thanks
Old Apr 21, 2010 | 09:58 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: subframe connectors
theirs no best they all do about the same thing some maybe do it better then others the more connecting points the stronger it will be
Old Apr 21, 2010 | 10:07 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
When I bought mine I went looking at the individual designs of them. They are all more or less the same with a few differences here and there in terms of connect points. You can get boxed or tubular. I think the boxed sub-frame connectors are easier to weld in personally. There are the S&W, Mac and Alston designs which are the only radically different sub-frame connectors from the rest. You can use the Mac sub-frame connectors along side conventional designs as they mount to a different area. Few have the S&W sub-frame connectors but they connect at some 8 points or something on the underside of the car. Those seem like the best design but they look like they could complicate exhaust routing or the installation of some components. That's just a guess from pictures I've seen in the past. I'm not actually sure as I've never seen them in person. Given their multiple connection points those are probably the single most solid design out there. If you aren't going to be welding these in yourself you need to think about installation cost. The more complex S&W sub-frames will cost more to have welded in than the normal sub-frame connectors will.
I think the ones I purchased were the BMR version.
Old Apr 22, 2010 | 08:41 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
What are the best SFC?? All of them. But to be the best they must be WELDED in correctly.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
