ASAP- Brake Vaccum Check Valve ??
I broke the plastic nipple on the black thing that hooks from the brake booster and vaccuum line on the TB. Can I just hook the hoses up without the plastic black thing?
HELP!! I have 15 min.
Justin
91 RS w/305TBI
K&N's
Looking for a B4C that is CHEAP, and doens't have a LOT of miles!
Got one, Let me know
Justin
91 RS w/305TBI
K&N's
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
My friends car did not have one and it worked fine.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I imagine you'd find that pedal effort and travel would increase as you came to a stop and vacuum dropped, on an engine with strong idle vacuum this might not be a problem. In a situation where the engine stalled though, you'd lose braking assist right away instead of having that one or two extra pumps.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
So what exactly does that metal line for the brake do that is hooked up to the back of the TB? (I have 1 on my carb and it is bent slightly)
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock will soup up when i get some $$$$$$$$$$
Car: 4
Engine: 6
Transmission: 5
Just go to Auto Zone and get a new one, it's in their Help section for like $5.
It's not "necessary" in the sense that something won't work if it's not there; but what it does, is hold your power brakes up for one or 2 applications after the motor stops running, which could come in real handy some day when you need to pull off to the side of the road without running over anything.
I broke the plastic nipple on mine, and removed it.. Ive been driving without it for awhile now, but towards lower speeds, when you lose vaccum, it isnt good, so when Im in town, I manually shift down to prevent that from happening, but, I am actually planning on replacing that this weekend... You can drive without it, just be careful!
-Roshambo
-Roshambo
