What to do next?
Old Apr 24, 2010 | 03:55 AM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
What to do next?
Ok I'm heading back to the states tomarrow froma 12 month tour in Iraq. I have purchased rear ALCA's and an adjustable panhard from Founders Performance, and a Wonder Bar from UMI. I'm wondering what would be my next smartest move? I have been looking at K members as well as a set of Eibach Pro Kit lowering springs (1" drop). Any idea's or suggestions?
Old Apr 24, 2010 | 08:07 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: What to do next?
subframe connectors if you dont have them
good tires and shocks/struts
prokit is not a bad choice for a street car
Old Apr 24, 2010 | 09:39 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
What are your plans for the car? that'll make a big difference in people's suggestions.
Old Apr 24, 2010 | 12:03 PM
Engine: 350 4bbl
I'm looking at street driving, auto X/ Road Course, and an occasional trip down the 1320
Old May 17, 2010 | 10:10 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I'm shopping for a K member only because I'm switching out engines AND I want the room for headers that don't have to get nocked, dented, etc. Most people on this board who really race and use their Camaro's hard don't recommend going tubular K's unless you're bored and rich.
One of the things I'm changing out on my 88 Iroc is a shock upgrade in all 4 corners with easy to adjust shocks. I'd also suggest saving your money up for a good quality brake upgrade.
I've done the full suspension treatment; except for the K member, and I'm glad I used lighter springs, didn't try to lowerer it past an inch, and used fully adjustable aftermarket front seats. Good Luck! Nitro
Old May 19, 2010 | 09:50 PM
Engine: 350 4bbl
Ok I have just recieved a set of Spahn weld on Sub Frame Connectors. So who's running them and can ya post some pics? Also I am going with a Chromoly Tube K member mainly for header/exhaust clearance and I hear it shaves a little weight off.
Joe
Old May 20, 2010 | 11:31 PM
Engine: 350 4bbl
Bump....anybody?
