Bad ball joint, or bad control arm?
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hi guys. I was doing a power brake infront of a 2010 Challenger while at the mall. When I got onto the main road, I noticed a banging sensation like if I have a bad wheel bearing. So I pulled over and slid under my small jack and began the tugging and pulling on the wheel. So I went home, had my wife record me in action so that I can show the problem in video. Here is the link. Any advice would be great. OHH, the passenger side doesnt have any play like the driverside. So is this the cause of the banging while driving?
Part 1. http://www.youtube.com/watch?v=hFPUcS_PXFw
Part 2. http://www.youtube.com/watch?v=-Aa7vcfN6IQ
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: Bad ball joint, or bad control arm?
Tie rod. Idler arm. center link . Check them. And yes that would make a banging noise
Cool. I just bought 2 sway bar links, 2 lower ball joints, 4 lower control arm bushings, idler arm. All I need is 2 new struts. Also, do I need the whole center link,or just the bushings?
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
um no one noticed the entire bal joint was moving in that video? IIRC the lower ball joints on these cars are pressed in with a C clip at the top, wither you busted your control arm, or the C clip flew out and you pressed the ball joint out with the brake torque. press new ball joints in and make sure the C clip is fully seated.
after that look into youre steering, looks loose too
Thanks Brandon. Well, on hand, I got 2 new ball joints, 2 new sway bar links, 4 new lower control arm bushings, a new center link, and the idler arm. Now I just need the struts but Im going to get em this coming month.
Agian, my IROC sits without any play time. Is there any thing else that I need to have my front end suspension up to par?
Agian, my IROC sits without any play time. Is there any thing else that I need to have my front end suspension up to par? Thread Starter
Also from the looks of the play in the ball joint, is it wise to buy a lower control arm from a junk yard?
the balljoint could have just pusghed out, ou'd have to check the fit with the new one
Good deal. Well since this has happened, Im close to buying all the parts needed to redo my front end suspension. Thanks Brandon.
ambainb
Apr 25, 2016 09:21 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
