does wheel size matter?
Old Apr 27, 2010 | 04:32 PM
89iroc-z559's Avatar
Car: 1989 camaro Iroc-z
Engine: 5.7 Tpi
Transmission: 700-R4
Axle/Gears: dont know what this
Ok i want to put 18x8.5 in front and 18x9.5 in the rear . my question is how much can i lower my car a 89 camaro without having any problems?thanks
Old Apr 27, 2010 | 04:54 PM
Bobby12's Avatar
Re: does wheel size matter?
I have 20x10's and 20x8.5's on my 84 Z28
Bobby12's Avatar
Not sure how you can lower using 18's though
Old Apr 27, 2010 | 05:07 PM
Stephen's Avatar
Car: 87 GTA
The wheel size itself won't really matter. Because with taller wheels you run a lower sidewall ratio tire, yet with the same (or close to) the same OVERALL diameter tire.
Tire diameter is what matters.....And width, of course, if you won't want any rubbing.
As for "How much can I lower a 89 Camaro without having any problems?" that kinda depends on the backspacing (offset). Too far out & you hit the fenders. Too far in & you hit the fenderwells. Get it right & you can easily go 2".
Old Apr 27, 2010 | 05:11 PM
Bobby12's Avatar
I agree that you should be able to get away with 2 inches. I wish I could remember the tire size I have on mine but could look whenever I get home. I did have to do a little "custom" work to the drivers side rear wheelwell.
Old Apr 27, 2010 | 05:25 PM
Engine: 5.7 Tpi
Thanks for all the help guys. Ok so if I go with 18x9.5 all the around what advatanges /disadvatages will I have. Also what size tires could I use? Thanks
Old Apr 27, 2010 | 05:54 PM
Stephen's Avatar
Car: 87 GTA
......I did have to do a little "custom" work to the drivers side rear wheelwell.
Obviously your rear axle was not centered, as is common on our cars.
With an adjustable Panhard Bar, you can center the axle and possibly avoid that, by getting it centered like it should be.
Almost a must on lowered cars. I know I've seen my share of offset rear axles even at stock height, on stock Panhard Bars.
BlueIroc-Z
Jun 9, 2019 03:22 AM
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
