Removing a wonderbar... What tools; specifically?
Old Apr 28, 2010 | 08:07 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I found an '86 IROC at a wrecking yard that is all but dead, but still has the original wonderbar. Since my 91 Z28 doesn't have one, I'd like this one. In an effort to make the removal as streamlined as possible (something about being under a car in a junkyard, in the south with creepy crawly things everywhere), what tools do I need to remove all things associated with the Wonderbar?
Any help, advice would be great!
Thanks!
Old Apr 28, 2010 | 08:13 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Removing a wonderbar... What tools; specifically?
should be just 4 bolts (same ones that hold sway bar up), it's like a 9/16 socket I believe....but take a few sizes. So a socket set and a ratchet, maybe a small extension. that's it.
Old Apr 28, 2010 | 08:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what he said
check your car and see what the bolts are that hold the sway bar to the frame mounts.
Old Apr 28, 2010 | 08:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
And take a sheet of cardboard or an old rug to spread on the ground.
JamesC
Old Apr 28, 2010 | 08:50 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Thanks for the info. Are the only bolts that I have to remove the same bolts that attach my swaybar currently? I thought the wonderbar used different bolts in the front?
Old Apr 28, 2010 | 09:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
no, its sandwiched on with the 4 sway bar bolts
Old Apr 29, 2010 | 06:57 AM
JamesC's Avatar
Here's a visual;
https://www.thirdgen.org/forums/atta...part-36mm1.jpg
Install how-to with diagram:
http://www.top-downsolutions.com/Doc...structions.pdf
JamesC
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
