Two types of strut brace mounts?
Old Jan 9, 2001 | 04:31 PM
jRaskell's Avatar
From all the pictures of various strut braces I've seen, I've noticed a variation in the manner of mounting to the strut tower itself. Some use some sort of mounting bracket in which the bar that goes across the engine bay mounts to. This results in a pivot point at the location where the bar mounts to the bracket on both sides of the engine bay. The edelbrock brace uses this type of mounting. Then there is the one piece brace that mounts directly to the strut tower with no additional brackets used. The BBK brace uses this type of mounting. It appears as though the bracketed type is the more flexible of the two, which I would think isn't a good thing. Obviously any strut brace is better then none at all, but does the one piece design technically offer the greatest amount of structural rigidity? (I'm not asking whether or not you can actually feel the difference in real world driving)
Old Jan 9, 2001 | 05:16 PM
CamaroMike's Avatar
A good pivot brace will be mounted to the cowl so the bar across the engine bay will not move on the mounting bolts at the strut towers. Although, a single welded piece is more rigid they are more difficult to install and remove for servicing the engine.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
J-money
Jan 4, 2019 09:45 AM
ericjon262
Sep 11, 2015 06:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
