STB for carbed cars
Old Jan 12, 2001 | 11:27 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
STB for carbed cars
Does anyone know who sells one for a carbed car with no hood clearance between the air filter? How much?
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam.
Old Jan 13, 2001 | 05:11 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
JDMZ28,
Edelbrock makes one that goes in front of the air filter and triangulates to the rear header panel(near the distributor). I've heard from some that it is difficult to install if you have AC on your car and a dual snorkel setup.
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 at 94.77mph
Old Jan 13, 2001 | 05:41 PM
Nor Cal Mike's Avatar
I have a dual snorkel air cleaner set up on my car. I have a homemade, two point STB and it fits with no problem. I have a V belt car.
The problems with the Edelbrock STB comes from the air conditioning bracket. Early 3rd Gens had V belts with the air conditioning compressors on the drivers side. Later cars, with serpentine belts, mounted the compressor on the passenger side. The Edelbrock unit fits the later.
In the archives, there are accounts of people using the Edelbrock STB with V belt cars by making modifications to the AC compressor bracket.
Nor Cal Mike
Red 84 Z28 HO, stock L82 350, L69 carb, intake, and air cleaner.
5 Spd, 3:73 Posi, 1 5/8" SLP headers, 3"cat connected to
stock L69 exhaust, KYB's, homemade SFC's,STB and wonderbar
Some are faster but mine's fast enough.
[This message has been edited by Nor Cal Mike (edited January 13, 2001).]
Old Jan 13, 2001 | 05:45 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I took my a/c off. The only concern of mine is the STB interfering with the air cleaner. I repeat, there is NO hood clearance between the air cleaner and the hood.
Old Jan 14, 2001 | 02:11 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Which air cleaner do you have? It should fit the single snorkel type.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Jan 14, 2001 | 09:31 AM
Chuck Everly's Avatar
Like mentioned before, if you do not have air or dual snorkel air cleaner the Edelbrock STB will work fine.
88 IROC convertible
-=ICON Motorsports=-
Old Jan 14, 2001 | 10:48 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
That was what I needed, thanks Chuck. I have a 14" open element. I was planning on fabricating a dual snorkel ram air later on, I hope there will be no interference. Are there any companies' that will not fit on a car like mine or chuck's? Thanks a ton.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
