Idler arm and Relay rod Replacement?
Old Jan 19, 2001 | 10:51 PM
Jono2's Avatar
Hi,
just wanting to know how easy it is to change an Idler arm and a Relay rod on an 86 Iroc and if anyone has some good tips for this job?
Thanks in advance.
Jono.
86 IROC-Z
305 4bbl 5sp manual
Right Hand Drive
Old Jan 20, 2001 | 08:23 AM
ede's Avatar
ede
fairly easy to do. all you need is a few sockets, or wrenchs for the nuts and a pickle fork. don't try it with out a pickle fork.
ICON Motorsports
1st & 3rd
Old Jan 20, 2001 | 11:03 AM
Wolfcoast's Avatar
Since you're replacing the idler arm also, I highly suggest you get a shop manual. The Chilton's doesn't really tell you all you need to set up it's height. I've got the Shop manual for an 84 so if you need some info, just email me at Wolfcoast@earthlink.net.
They are both pretty easy to replace. I just replaced the relay rod on my 84 Z28 and it only took about an hour total. The only reason it took that long is getting the relay rod off of the idler arm was a B*&*&. Definitely use a pickle fork. Makes it soooo easy.
Randy
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
BRoss99
Aug 10, 2025 05:08 PM
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reborn756
Sep 4, 2015 03:42 AM
