I need a little 1LE brake help
Old Jan 24, 2001 | 05:10 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I am retro fitting my '82 Z28 w/1LE front brakes,and other stuff. I found a set of new loaded front calipers that have been on a shelf for a long time. but the little spring clip that goes onto the pads is missing from one of them. I only need one of these little clips. Does anybody out there have an extra clip from a set of old brake pads. I tried the mfg with no luck. Thanx,ANDYZ28
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Jan 24, 2001 | 02:12 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Hey, I did that a while ago, except I used all new parts... the clips you are talking about (2 per pad, 4 per caliper) are sold with the pads themselves. I lost one and nearly bought another set of pads to borrow the spring from. That should work for you.
FWIW, the pads I used were AC Delco Durastop.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro ZZ4 M5 (V-6 in a former life) -- street beast
'91 Medium Blue Metallic Z28 A4 (UB-HSTRY's old ride) -- currently broken
'99 Navy Blue Metallic Firehawk #120 M6 (99.44% stock) -- daily driver
Old Jan 24, 2001 | 02:15 PM
99Hawk120's Avatar
BTW, since the calipers are "pad-guided", missing pad springs WILL cause the caliper to klunk when first applying the brakes. I chased that for months. Also, be SURE to put the calipers and brackets on the correct side, I had mine backwards which didn't help.
AFAIK, the caliper is seated in the top of the bracket and then the bottom is rotated in.
Old Jan 24, 2001 | 05:21 PM
ANDYZ28's Avatar
Car: 1982 Z-28
mine are 1 spring per pad. does anybody have apare spring? even a used one will do?
Old Jan 25, 2001 | 08:46 AM
99Hawk120's Avatar
You really need two springs per pad. Otherwise the brakes will clunk. The guy that knocked it down to 1 per pad probably didn't know this.
I did that to mine, and they klunked, so I ended up putting the second spring back on all the pads.
[This message has been edited by 99Hawk120 (edited January 25, 2001).]
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
