Sway bars and Stiffness
Old Jan 26, 2001 | 06:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I searched the archives, but while the diameter was discussed, no one ever mentioned stiffness well enough to suit me. Aside from the the 36mm's being lighter, is it as stiff or stiffer than a 32mm solid bar (which is what I believe I have on my 85 IROC)?
JamesC
Old Jan 26, 2001 | 10:05 PM
84IROC's Avatar
The 36mm bar will probably be about the same as the 32mm bar (maybe a little less) due to the 36 being hollow. I opted for the 36 because of the 9 lbs. difference in weight.
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front ($10 from wrecking yard)/
"wonder Bar" ($5 from wrecking yard)
23mm sta. bar in rear
Rear RS Springs (slightly softer than my Z28)
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
powersteering cooler lines (liberated from another wrecked car of course)
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit btw)
home-made strut tower brace (cost $6)
Rebuilt engine and transplanted it myself.
Love this engine!
freshly painted OCT. 2000 Teal with two white stripes on the hood and deck lid
LOW performance people should drive low performance vehicles!
[This message has been edited by 84IROC (edited January 26, 2001).]
Old Jan 27, 2001 | 05:25 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Are you sure that the difference is 9 lbs.? I don't think that the whole thing weighs that much. I could be wrong though.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 27, 2001 | 08:04 AM
SteveSpohn's Avatar
He is correct n the weight.
Spohn Performance: F-Body Chassis/Suspension Specialists
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
gord327
Sep 29, 2015 10:18 PM
