Please help!!!!!! ASAP!!
Old Jan 29, 2001 | 03:23 PM
infodash's Avatar
The front drivers side brake on my 89 iroc is locked up. I replaced the calipers and break pads yesterday, bled the brakes and it still won't release. Now, if I can get the car to move it pulls hard to the right like i have the steering wheel turned all the way to the right.
Old Jan 29, 2001 | 04:39 PM
buddman91rs's Avatar
all of the third gen's came stock with a floating caliper, check to see if the caliper is seized on the rods it slides on.
Old Jan 29, 2001 | 05:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Chances are the brake line is bad. For some reason the brake line swells (or collapses depending who you hear it from) and severly restricts the brake fluid in the line from returning keeping pressure on the caliper. Usually it will drain back (like overnight) and will be fine for a short while until the pressure builds again locking the brake back up. Hope that helps
My Firebird
Part Diagrams
Old Jan 30, 2001 | 09:54 PM
OutlawFormula's Avatar
I'm with Deadbird, replace your rubber brake hose.
91 Formula
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
