front end squeaking noise
Old May 10, 2010 | 09:07 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
So When I first got my GTA the front brake lines were screwed up, and the car wobbled all over the place when braking. The dealer I bought it from replaced the brake lines, and front calipers. Now ever since then the front end made a squeaking noise upon braking. If you look at my videos below, you will see what I mean. It doesn't make any noises going over bumps, around corners, or braking going backwards. It only makes the noise when I stop at a certain force. I always thought it was the front end and it would be like that until I had the money to rebuild it, but now I saw another thread on here that was talking about the brakes making a similar noise. So I want your guys opinion, what do you think its from? Once again, the car ONLY makes the noise at the end of braking right before it comes to a stop. I can go over speed bumps, up my driveway, bumps, no noises at all. It drives and stops straight as an arrow. The font end has been greased up multiple times recently as well.
Old May 10, 2010 | 09:34 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: front end squeaking noise
it's usually the pads. i always have good results with autozone pads. i use them on all my customer's brake jobs and my own vehicles. no complaints.
Old May 10, 2010 | 09:54 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Ok, I guess I will have someone drive the car so I can listen to which side its coming from... Thanks dude, I really hope its something screwy with the pads..
Old May 10, 2010 | 09:59 PM
cool. i assume there is an autozone in vegas? they will replace them for free, even if they just wear out.
Old May 10, 2010 | 10:22 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
yes there are autozones in vegas. The car has done that for the past two years and its really ****ing annoying.. my moms van has has sway bar bushings go bad before and it made a clunking noise, but it did it during braking and turning. my car only does it when braking..
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
B_Dubya
Aug 26, 2015 05:09 PM
