IROC Steering Question
Old Feb 2, 2001 | 04:31 PM
Basett Racing's Avatar
I bought an 86 IROC yesterday CHEAP for parts. I want to upgrade the handling on my 89 RS,I already have some 82 Z28 stuff on there ,but I plan to put all of the IROC stuff on my car. I recently put KYB struts and shocks on the car, so I won't be changing those, but I plan changing springs, sway bars,w/all polyuretrane bushings, and installing the wonderbar. When I change front springs, I'm going to replace the ball joints, tie-rod ends and the idler arm. My question is about the steering box, is it different than the 89 RS one?? If it is I want to cahnge it too, but I don't want cahnge if they're the same. Thanx
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
Old Feb 2, 2001 | 10:10 PM
84IROC's Avatar
The "quick" ratio steering box will have a number on the top that ends with '525 and a large "Z" embossed directly below this number.
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front ($10 from wrecking yard)/
"wonder Bar" ($5 from wrecking yard)
23mm sta. bar in rear
Rear RS Springs (slightly softer than my Z28)
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
powersteering cooler lines (liberated from another wrecked car of course)
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit btw)
home-made strut tower brace (cost $6)
Rebuilt engine and transplanted it myself.
Love this engine!
freshly painted OCT. 2000 Teal with two white stripes on the hood and deck lid
LOW performance people should drive low performance vehicles!
Old Feb 2, 2001 | 10:19 PM
bullfrawg's Avatar
does you car with the 160 thermostat get over 150 degrees?
If it doesn't you may be losing power and fuel milage. I put a 160 in my 85 ta and it still overheated. The i put on a new airdamn under the radiater and it won't get above 150. I lost a lot of power and about 7 mpg in fuel.
Old Feb 3, 2001 | 12:56 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I recently discovered the Iroc has a 7-ply rag joint in the steering joint. The RS has a 4-ply one.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Mar 22, 2019 09:39 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
