Intrax Lowering springs
Are intrax lowering springs any good? I can get a set of 4 for $100. Should I do it? Also how much better will my car handle with these if I put thwem on over the stock WS6 setup and Also go from my 15" ARE wheel to a set or 4th Gen 16X8's with 50 series tires? I already have a Poly urethane front end kit.
If I do this should I also put on lower control arms and a new pan hard rod?
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Hook me up!! How can you get them for that cheap? I would definately go for it. I've been holding out for them.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Dude some company was selling them on ebay for a bunch of cars. Starting Bid was $100 on all types and nobody else bid on the ones for 82-92 F-body. You can check back there and see if there is anymore of them.
Thornburg
Sep 12, 2015 10:11 AM
