knocking sound
Old May 16, 2010 | 12:52 AM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
knocking sound
i cant find this this for the life of me. there is a pretty loud knocking sound when im driving. i know that it is coming from my driver side rear wheel. i think that its knocking at a certain point because it seems to be a knock for each rotation of the wheel. the knocking goes away when i apply the brakes. i have a stock GTA set up with C5 Z06 rims with 275s out back so i dont think its rubbing.
thanks
Old Feb 14, 2013 | 07:48 AM
joeabate19's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6
Re: knocking sound
thanks
hey i know this thread is two years old but i have the same problem and was wondering if you figured out what the problem was. thanks
Old Feb 14, 2013 | 08:20 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: knocking sound
If your sound goes away with braking id start by inspecting the brakes.
Old Feb 18, 2013 | 07:32 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
Re: knocking sound
check the bolt to the panhard bar? might be loose.
btw are you running discs or drums
Old Feb 19, 2013 | 07:56 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: knocking sound
Yeah, more info is needed. If you have discs and it occurred with every turn it could be a warped rotor or the clips are not on the brake pads. start by jacking up the car and making sure all bolts are torqued correct and the sway bar end link is not rusted or cut apart. Could also be a broken belt in the tire?
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
wanext
Oct 6, 2015 12:18 AM
efiguy
Sep 27, 2015 01:30 PM
