5604 vs. 5610
Old May 16, 2010 | 07:55 AM
Tash3r's Avatar
Car: 86' Sport Coupe
Engine: LG4 305
5604 vs. 5610
I am planning on getting new springs for my car since they are stock. I already know what rear springs I am going to get but I wanted some advice on the front ones. At the moment this car is a daily driver, would you guys recommend stiffer or softer springs.
The Moog 5604's have a 347 spring rate.
The Moog 5610's have a 424 spring rate.
Or if you guys know any other other brand or part # that are better, I'm up for suggestions.
Old May 16, 2010 | 12:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 5604 vs. 5610
the softer rates maybe v6 springs, i would go with hte stiffer ones personally. those rates both seem to be low though, the iroc springs are 706 lbs. #5662
Old May 16, 2010 | 09:24 PM
Tash3r's Avatar
Engine: LG4 305
Re: 5604 vs. 5610
Which one would you prefer, the iroc springs or the the ones with the 424 spring rate?
Old May 17, 2010 | 06:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 5604 vs. 5610
iroc ones, the others are way to soft
maybe get the matching rears too. The springs will raise the car, so you may have to trim them a little, but they are good springs. Used to have them
Old May 17, 2010 | 08:24 PM
Tash3r's Avatar
Engine: LG4 305
Re: 5604 vs. 5610
sweet thanks man
3.8TransAM
Sep 17, 2015 02:16 PM
CLEE
Jul 4, 2003 11:38 AM
92RSB4C
Oct 18, 2001 05:49 PM
FullSendRacing
Aug 29, 2001 08:18 PM
