As of now my suspension is 100% stock. I am always looking for something to enhance. I thinh my idler arm needs replacing, but other than that what is/are the first things I should look at replacing in order to enhance performance? springs, LCA's etc
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat,
160 stat,
I'm assuming you have a '92 RS. I also have a '92 RS. I found that a strut tower brace along with a new panhard bar helped tremendously. I have yet to do subframes though; those are supposed to help a lot too.
Yes, as my name implies I have a '92 CAmaro RS. And as I said shes prety much stock save for the sway bar end links. As for the panhard bar how hard was it to install?
160 stat,
160 stat,
It's just two bolts. It took about 25 minutes. You do have to jack the car up and set it on stands so if you dont have the right tools it might be a bit difficult.
If your planning on lowering you car later on, make sure you get an adjustable bar, otherwise stick with a non-adjustable one. I say this because the jam nuts on the adjustable ones might work loose after time.
I bought the standard Edelbrock bar from Advance Auto Parts for a little more than $100. You might find one cheaper online, but if you have any problems it's easier to return stuff to an actual store.
