Panhard bar question....
Old Feb 9, 2001 | 02:55 AM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
I need to replace the two bushings at both ends of the Panhard bar. Every parts place, including the dealer, is telling me that the bushings are not servicable and that I have to buy a whole new bar.
Is this true?
If so, what are the differences between the "aftermarket" Moog unit and the "factory" GM part?
Thanks.
'89 GTA: blk on blk with 5.7 liter, T-tops, leather, N10 dual exh with 76,500 original miles. 100% stock including the ZR50 Goodyear "gatorback" tires.
Old Feb 9, 2001 | 07:38 AM
valu8or's Avatar
I am not sure if they are serviceable or not, but SLP has take off panhards for $17.00 or so. I would think the bushings would be around that if you factor in the time to install and such.
Old Feb 9, 2001 | 07:47 AM
valu8or's Avatar
I just found this you might want to take a look at http://cgi.ebay.com/ebaymotors/aw-cg...040591&r=0&t=0
Old Feb 9, 2001 | 09:18 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I was able to replaced my bushings on my stock panhard rod. I replaced it with polygraphite
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Old Feb 9, 2001 | 09:54 AM
Tallboy's Avatar
it seems like anybody off the street can be
a "mechanic"
stick with this board and read read read
and soon u will trust no mechanic short of an a.s.e. degree
and if youre a gen x'er everyone will think youre trying to be a know it all but U just have access that all these stupid indbred idiots dont and choose not to accept...
im fine ,no really
Old Feb 10, 2001 | 09:56 PM
Metalifann's Avatar
For the time you're going to spend replacing the bushings, just replace the whole bar for a few bucks more. The aftermarket bars are much much better. They are well worth the money.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
