brake question within help please...
Old Feb 11, 2001 | 03:59 PM
pimpintheRS's Avatar
i just recently changed my front rotors and pads because my car was squeling when i would drive and stop only if i tapped the brakes. well the noise went away for about 2 months and has now returned i am in the process of changing the calipers now as i type or as soon as i quit typing. Do you think the calipers will be the fix to my problems or should i change the hoses for good measure? What else could be my problem? I believe it is the caliper not retracting completely and causing the squeling does that sound right? thanks my car appreciates it!
Shawn
Old Feb 11, 2001 | 04:40 PM
Jza's Avatar
Jza
Try using this stuff called Disc Brake Quiet. It's an orange bottle that looks like an Elmer's woodglue bottle. You spread that on the back of the pads and it finally got rid of my squeal.
Old Feb 11, 2001 | 08:37 PM
did your car squel when you put the brakes on or when you drove normal?
My car squels all the time and only stops when i apply the brakes. EVEN AFTER i put the new calipers on and brake lines the car still squels everywhere i go....
What could that be? bearings? help please. the squel is annoying i drive everywhere with my stereo turned up.
Shawn
Old Feb 11, 2001 | 08:55 PM
could it be the bearing i packed the grease into when i changed the rotors? sorry i am going crazy wondering what thi squel could be.
Old Feb 12, 2001 | 10:28 AM
Old Feb 14, 2001 | 02:20 PM
thanks for the suggestion. i fixed it. It ended up being a combination of my backing pad that caused the problems and using that stuff as described above that fixed it.
thanks
Shawn
[This message has been edited by pimpintheRS (edited February 18, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
