Changing tire sizes
Old Feb 11, 2001 | 10:14 PM
DSouthern's Avatar
Changing tire sizes
I believe my 87 GTA with the stock 16 inch gold mess wheels and 245/50ZR16 tires has a little too much space between the tires and fender well.
I know one fix is to go to 17 inch wheels, but I like the stock wheels and don't want to replace them right now.
Will changing to a taller tire fill up this space some?
Do they even make a 235/60ZR16 tire?
Also, will a taller tire rub on the fender well as the suspension is compressed during normal street driving?
Old Feb 13, 2001 | 02:44 PM
BTS88IROC's Avatar
You could maybe get a taller tire, but I'm not sure how good it would look. Why don't you just get a one inch spring drop kit or something. If you get a different tire then you will throw off the speedo some too.
Old Feb 15, 2001 | 04:31 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You can put a 255/50/16 tire on the car. I just put a pair of Toyo Proxes F1 tires on my rear and it looks better than the 245/50/16 I had.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Feb 15, 2001 | 02:04 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
DS,
255's do make a small amount of difference but if you want a killer stance and look the only way to go is with 18"rims.I have 9.5 rear and 9"fronts all with 265/40x18" Bridgestones.Yes they are quite expensive but well worth it.While you are at it lower the car with springs from a reputable supplier,I used Edelbrock.Check out the pics on www.lintonbros.ic24.net/car1.jpg
/car2.jpg
Good luck
Powermite
Old Feb 16, 2001 | 03:33 AM
Jza's Avatar
Jza
Giant sidewalls look like a$$. The turd who had my old 84 before me put Seiberling truck tires on it. I smacked him in the back of the head for that one.
Best thing is just to lower the car with some springs. Cheaper than a set of tires, plus it helps your handling out some.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
forstral
Aug 19, 2015 03:20 PM
knight72
Aug 10, 2015 09:32 PM
