Need to Raise the Front .5"
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Ok i got my springs installed today and the rear looks sexy. But...the front is just too low. I jacked the car up half an inch and it looks perfect. How should i raise the front that little half inch? i know it doesn't sound like much but it makes a huge impact appearence wise.
I know there's some things that go inbetween the coils to raise them a bit, would that work? I'm sure it'll raise the spring rate, but i really don't care. Or is there some kind of spacer that can go on top of the spring perch other than the stock insulator?
Thanks guys
Thanks guys
Car: 87 GTA
Re: Need to Raise the Front .5"
I'd recommend using thick rubber/urethane insulator instead of those cheesy little things that fit between the spring coils.
No idea who makes them though. I'd look in the 4x4 world though, to find anything to lift a car.
Or get weight jacks.....Just a turn of the wrench & the car is higher.
Car: 89 IROC-Z
Weight jacks are coming some year! Prolly when i put in a k member if i don't go coil over.
The only problem i'm seeing now if i put a spacer on top is how reliable is that? I mean the perch that the spring goes around up there isn't very deep, and i could see the spring sliding off that spacer. Those things that go between the springs are really cheap, and if they work they work lol. It's not like i'm raising it 1+ inches
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
use the rear spring insulator on the front, maybe cut it down a hair. It should locate over the hump in the k-member pocket and raise the car at least 1/2", probably more like 3/4, hence cutting it down a little
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
those cheesey little things that fit between the coils are called spring rubbers. They are used if you need to stiffen a spring rate a little. They are an easy alternative to changing a spring if you need a small adjustment at the track. They are not intended for use as a spring spacer.
Car: 1992 Camaro RS Convertible
Axle/Gears: LS1 posi/disk 3.42
would any of these work? im looking to do the same thing
http://www.autozone.com/autozone/cat...pring+Isolator
Edit: never mind found some on summit
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
