Turn angle and lock-to-lock ratio
Old Oct 3, 2008 | 07:05 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Hi,
How can i extend wheel turn angle?? i'm planing to drift with my fbody and i need to extend extend it as much as possible.
Also i need to lower the lock-to-lock ratio, how can i do that and which parts to choose??
best regards
Old Oct 3, 2008 | 07:11 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Turn angle and lock-to-lock ratio
You'll need to get a quick ratio steering box with 2.5 turns lock to lock. They called it "sports steering" back in the day.
Old Oct 3, 2008 | 07:20 PM
WASyL's Avatar
will be just marked 2.5 turns lock to lock or any other way ??
best regards
Old Oct 3, 2008 | 07:29 PM
WASyL's Avatar
can You give me any links to webpages showing those because it is hard for me to find exact products as english is not my native language
Old Oct 3, 2008 | 08:49 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I believe what hold the steering back is the stops on the a-arms, but I'm not positive about the steering box itself. I just know that I'm using a manual box from an s-10, and before I put it in the car it would take 7 turns lock to lock. Now in the car it only goes 4 turns lock to lock.
Old Oct 3, 2008 | 10:07 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
The steering box has internal stops in it. You'll want to find a box with the code Z that's the quickest ratio out there.... you may also want to consider what rims the car came with. Since the 15" and 16" internal stops are different
Kevin84Z28's Avatar
Here's one from Ebay, they show up pretty frequently there.
http://cgi.ebay.com/ebaymotors/89-Ir...spagenameZWD1V
Old Oct 4, 2008 | 07:52 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Try to get hold of the member "CrazyHawaiian". I think he's been into drifting for several years already.
Norm
Old Feb 12, 2009 | 07:15 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
I kinda missed your threadd, did you ever find this one?
https://www.thirdgen.org/forums/susp...ing-angle.html
Old Feb 12, 2009 | 07:24 AM
WASyL's Avatar
actualy i did found that thread and managed to make what i needed to do
best regards
Old Feb 12, 2009 | 08:33 AM
BMR Sales's Avatar
Former Sponsor
You could try a steering quickner in your shaft. You would have to modify it for this to work http://www.speedwaymotors.com/SMALL-...KNER,8280.html
Also the main thing thats going to give you more angle is modifying your tie rod mounts on the spindle. You want to bring the mount closer to the center steering pivot point on it. That way even with the stock rack you'll get more throw left to right. Like this...
http://www.mamsparts.com/
Scroll down about a page and you can see their modified spindles and the crazy steering angle.
Old May 28, 2010 | 04:45 AM
WASyL's Avatar
digging form the grave, BMR as im about to start modifiy the spindles, from what you said i need to shorten the arm of the tire rod mount so do like shown on picture ??
best regards
Warlocksirix
Sep 3, 2015 12:26 PM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
gixxer92
Sep 1, 2015 04:32 PM
luvofjah
Aug 29, 2015 08:33 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
