Would a bad Idler Arm cause this???
Old Feb 20, 2001 | 04:42 PM
irocbsa's Avatar
I don't think it would but I'm trying to narrow down a persistent problem..........When I hit a bump or, occasionally, when I am braking the steering wheel will shake back and forth violently. If I turn the wheel back and forth it will stop. I have checked the tie rods and the rotors are not warped. There is not a crack in steering box area. When I went in for an alignment, my regular shop told me I my Idler Arm was on the way out. Would I see these symptoms from this type of defect. Thanks.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Feb 20, 2001 | 11:47 PM
Ryan Lakatos's Avatar
Yes!!! Had the same problem and it fihed it on mine.
1988
Firebird Formula
305 TPI
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
