Power steering pump replacement
Old May 26, 2010 | 08:34 PM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
I am not sure if this goes here, but I thought that I would try and see what kind of help I can get. I have a pump with a reservoir and the new one looks like it has two places for something to go in there. I can see on the old one that there is something there. One look like just a plug and the other is a bolt that screws into the pump. Anyways, do I need to put the two items from old pump on the new one? If I do how? I don't have a vise or a impact handy. Thanks.
Old May 26, 2010 | 08:54 PM
brutalform's Avatar
Re: Power steering pump replacement
Yes, switch them over. Not hard to remove. a deep socket and ratchet should suffice for the stud, and a flare wrench for the plug.
IIRC, you might need a new hose so you do not void the warranty...not sure though...its been a while since I changed one.
Old May 26, 2010 | 11:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you wait an extra day, you can get the pumps with the res already attached for only $10 more at AutoZone - they don't usually have them on shelf but can get them in a day - $51.99 + $7 core IIRC. Then all you have to do is take lines off old, install on new - easy.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
