Upper strut mount movement?
Old Feb 22, 2001 | 05:14 PM
NickS's Avatar
The car is a '92 Z28.
Last night I pulled the cut stock springs, and the Koni hydraulic struts and put 900lbs springs and the yellow Koni sport stuts in.
After swapping the RF strut out, I noticed that part of the mount that the top of the strut bolts to moved about 1/2" up as weight was applied to the RF wheel as I lowered the car back down.
I checked the LF which I had not swapped out, and noticed the same symptoms. I went ahead and swapped the LF out and saw the same things.
Is this sort of movement normal??
Thanks!
-Nick
'92Z28 - CMC #45
Old Feb 22, 2001 | 08:33 PM
Stephen's Avatar
Car: 87 GTA
Did you replace the stock strut bushing? IIRC, there is a bushing up there and that could account for some movement I suspect.
Stephen Cranford
http://www.geocities.com/chevyraceshop
http://austin.f-body.org/members/cranford
97 Tahoe SS
90 Camaro RS
Old Feb 22, 2001 | 08:59 PM
NickS's Avatar
No, I haven't changed the shock mounts out, as far as I know, they are the orig mounts with about 65k mi on 'em.
Thanks!
- N
Bubbajones_ya
Jul 6, 2024 08:32 PM
J-money
Jan 4, 2019 09:45 AM
rb85TA
26
Sep 14, 2015 10:29 PM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
