lca reloc bracket
Old Mar 3, 2001 | 12:16 PM
92formula's Avatar
Car: 1992 formula WS6
Engine: none
lca reloc bracket
if i lower my formula one inch or 2inches would i have to get the LCA reloc bracket. I have hotckhic lower control arms. I thinking about eibach springs
Old Mar 3, 2001 | 03:52 PM
scauffiel's Avatar
You don't have to do anything. Will it help? Yeah, probably. Will it hurt? No, probably not. At $65, does it really matter?
Steve
Steve's Trans Am Temple
Old Mar 3, 2001 | 03:53 PM
92formula's Avatar
Engine: none
Very true
Old Mar 3, 2001 | 04:17 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I would reccomend it. Lowering your car will change the suspension's geometry, and having the back of the LCA HIGHER than the front will induce wheel hop. Thats the point of the relocation brackets, to move the back of the LCA lower than the front where it should be.
Here is a quick install link: LCA bracket install
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 3, 2001 | 07:14 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I have the brackets from Steve Spohn and I'm glad I put them on. My car was very unstable at highway speeds with the control arms pointed in an upward direction. After the brackets and setting them to the lowest position-instant stability. The car launches from a standstill so much more straighter than ever before. The rear feels very solid as well. while not absolutely necessary they are well worth the money for lowered cars.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
