To all those who say '88 and older disc sucks.
Old Feb 23, 2001 | 07:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I am wondering what your basis for judgement is. I just installed a rearend from an '88 IROC w/ disc brakes into my T/A that had drums. The discs stop just as good, if not better than the drums. The drum brakes were properly operating, and fully adjusted as the basis of comparison. After the swap, the pedal was low, but a simple adjustment of the E-brake cable fixed that. The brakes work great, and the E-brake holds better than the drums.
Of course, proper maintnence will be required to keep them this way, but I have yet to hear from somebody who actually likes the '88 and older style.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 23, 2001 | 08:47 PM
MikeDwhoROCZImports's Avatar
It's not that the 88-older are horrible, just that it's not difficult to find an 89 or newer rearend with disc's, and the price will only be slightly more if at all. I picked up my 89 posi 9-bolt rearend with 3.27 gears and aluminum calipered disc braked for $250. Not a bad improvement for the money over my 87 open 10 bolt rearend with 3.23's and drums, for the money.
Old Feb 24, 2001 | 12:24 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I think the 'horrible' part lies w/in the 'rachet action' adjuster on the older style calipers (which I have & don't see the problem either,, but heard they have been to some)
My Firebird It Lives Again!!
Your Car Here?
Part Diagrams
Old Feb 24, 2001 | 07:19 AM
Biochem's Avatar
Car: 2002 SOM z28
I had a hell of a time installing the e-brake with that stupid spring on a pre-88 9-bolt. Though I don't think I had my e-brake adjusted loose enough when I was trying to do it either.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Feb 26, 2001 | 12:18 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
GMTech:
Mine worked excellent for about the first 3000 miles and then slowly came out of adjustment. Wait a little while before making your judgement.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro ZZ4 M5 (V-6 in a former life) -- street beast
'91 Medium Blue Metallic Z28 A4 (UB-HSTRY's old ride) -- currently broken
'99 Navy Blue Metallic Firehawk #120 M6 (99.44% stock) -- daily driver
Old Feb 26, 2001 | 12:31 PM
DaveZ24's Avatar
I am getting ready to do this swap into my 84 Firebird this summer. I guess I am lucky in that I am getting a rear-end out of an 84 Camaro. Simple swap, and i can't wait to put the discs to work late braking in to hard turns.
One Man...One Search...One Goal...MORE POWER!!!!
84 V6 Firebird in sad, but mechanically sound shape. Currently gathering parts for a performance restoration, i.e. restore the body and interior, then stuff as much HP under the hood as possible.
Any body know of a good resto shop??
Just a Nitro guy living in a Nitro world!!!!!
Old Feb 26, 2001 | 02:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have heard that changing the brake pads is a pain in the *** with the 82-88 disc brake rears... Plus who doesnt like having larger brakes? The good thing about them, the front and rears take the same brake pads.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Old Feb 26, 2001 | 05:02 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Mine woorked fine ( iwent from drum to 88 iroc rear disc to 92 rear calipers and 89 9-bolt backing plates) I just wanted the bigger brakes and I think the new ones look cooler.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Mar 1, 2001 | 09:45 PM
Superblue87Formula's Avatar
my car has the factory rear w/ discs, and I can change the brakes in 30 minutes easy..
Old Mar 2, 2001 | 07:23 AM
Kyle F's Avatar
My brakes were easy to change on the rear.
Now the brakes son't work the way they used to. Extremly soft, I have another question asking what the problem is on the board. Maybe you guys might want to shae info on that chain.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added. Soon to have Intrax lowering springs.
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Old Mar 2, 2001 | 10:06 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The '84 discs I put on my '86 aren't working that hot... well, the passenger one works great, the driver's side doesn't. I've gotta get that GM repair kit, that's all... but right now, it's too damn cold to do the job.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 2, 2001 | 10:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The rear discs on my 85 IROC, 5-speed, have always worked well. The key, I think, is regularly using the e-brake. Someone correct me if I'm wrong, but I believe the e-brake adjusts the calipers. At any rate, I've never experienced any difficulties. There is a TSB relating to the problem in general, but only for manuals, so for some of you, a free fix may be in order.
JamesC
[This message has been edited by JamesC (edited March 02, 2001).]
Old Mar 3, 2001 | 10:26 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I replaced my whole 4-wheel disc brake system,exept the metal lines and prop. valve,with parts from autozone. I used Autozones "carbon-mettalic" pads all around.my brakes work awsome,I could throw your A$$ throught the windshield if you weren't buckled up..you have to remember that it is an antique brake system,no ABS or slotted rotors. I have different tecniques for different stopping situations. most of the time I tap the pedal to "set" the pads,then I work the pedal letting the rotors cool,composite pads are designed to heat up faster,because they are originally developed for aircraft landings. they tend to get hot at sudden stops,so I just chase that "sweet spot" in braking pressure.
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
wanext
Oct 6, 2015 12:18 AM
indygene
Sep 26, 2015 11:21 AM
