17" Tires
Old Feb 27, 2001 | 09:52 PM
iroc51578's Avatar
17" Tires
Could someone give me some information on the best size tires for 17" rims. I want to have no clearance problems. I figure I may have to have two different sizes for the front and back. Any information would be greatly appreciated.
Old Feb 28, 2001 | 09:12 AM
Z28DJP1987's Avatar
245/45/17 tires are what Iam using on 17x8.5 wheels front and rear with no problems. 1987 IROC.
Old Feb 28, 2001 | 09:45 AM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
There are lots of us running 275x40-R17 front & rear on 17x9 rims.
Another coomon configuration is 255 45 R17 up front with the 275's in the rear.
Some are also running 315's on 17-11 rims in the rear
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Feb 28, 2001 | 06:58 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I'm running 275/40/17's in the rear on 17x9 and 255/40/17 on 17x8 in front.
Old Mar 1, 2001 | 01:22 PM
superz's Avatar
how the crap are they runnin 17x11??!! i wanna see that i bet that looks sweet as hell!! what has to be done to do that? just lots of rim offset?
Old Mar 1, 2001 | 03:37 PM
KevinP92Z's Avatar
For a quick search there are a couple of pics in this thread:
https://www.thirdgen.org/messgboard/...ML/000188.html
KevinP92Z
Old Mar 3, 2001 | 08:15 PM
Tas's Avatar
Tas
most of those pics didn't work I think I'm gonna get some 17x9.5" boyds with 5.5" backpacing so I can rotate them.
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz | ICQ 82881207
Old Jan 18, 2008 | 11:29 AM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Re: 17" Tires
I would like to see a 17-11 setup also! I did a search and found nothing.
does anyone have pictures of someones ride with this setup?? thanks.
Old Jan 18, 2008 | 05:02 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Re: 17" Tires
I've got 11s on back. Just a stock ZR-1 offset and 1" spacer/adapter. No spacers with a 4th gen rear. Had to flatten one small area in the wheelwell and that was it. I'm only running 275 wide, though. The guys with 315s probably have to do a little more work.
Old Jan 18, 2008 | 08:38 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: 17" Tires
As far as I know, that's all you have to do to run the 315s. Just play with the inside of the wheel well a little. I plan to get a set as soon as I can...just so I can show em off, don't really need them.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
