how much $$ to change struts
Old Mar 1, 2001 | 03:25 PM
jason86/2.8's Avatar
Because of the way my tires are wearing I think my front struts are going bad. About how much would it cost me, in general, to have them replaced?
Red 1986 SC, 2.8L, rebuilt 700R4, 3.42 Posi, t-tops, 137K miles and counting, K&N air filters w/ removed air baffles, hopefully more to come!
RIP #3
Old Mar 1, 2001 | 04:15 PM
Blue92's Avatar
Man you can do that by yourself. The only problem will be the bolts at the bottom. Very tight, but save yourself a lot of money and try to DIY. That way you can buy better struts with the money you save on installion.
BTW, push down on the front of your car real hard and if it keeps bouncing a couple of times then your struts are worn. If it bounces just once then they are most likely fine. Look elsewhere for wear problems.
http://albums.photopoint.com/j/View?...781&p=29492901 http://albums.photopoint.com/j/View?...781&p=29492902 http://albums.photopoint.com/j/View?...781&p=29495767
"DriveHarder"
Stock 305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
[This message has been edited by Blue92 (edited March 01, 2001).]
Old Mar 1, 2001 | 04:39 PM
Mo's Avatar
Mo
It cost me $50 per strut (KYB), $0 for installation, and whatever it costs for alignment.
90 IROC 5.7l (L98)
ram air, K&Ns, air foil,Flows
LIKE A ROC
Old Mar 1, 2001 | 10:35 PM
Hulk0202's Avatar
If the only problem is the tire wear, you may just need an alignment.
Old Mar 4, 2001 | 07:07 PM
Thing is I just got my front end aligned a couple months ago. I did the thing about pushing my car down and it down bouce 3 or 4 times.
RIP #3
Old Mar 4, 2001 | 07:19 PM
Keith5's Avatar
Car: C1500
You can do it yourself, but it has to be realigned after you do it.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
