New Delco P/S pump leaks like a siv
Old Jun 4, 2010 | 12:16 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
So I put my new pump on and it leaks like crazy. There is a little red plastic plug on the back of the pump body that seems to be the culprit. I tried to coat it with some hylomar and see if that would stop it, no dice. I am going to take the plug out and see if I can find one that fits more securely. Anyone else run into this? I know these pumps tend to cake up over time, but this one is off the shelf and it's leaving a decent size puddle overnight. I'm running royal purple p/s fluid in it, maybe it's too thin of a fluid? Thanks
Will
Old Jun 4, 2010 | 02:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: New Delco P/S pump leaks like a siv
Odds are that a bolt is required at that location. There are several mounting holes in the rear of the pump. Depending upon the application they either get a bolt or a double ended stud (hex in the middle). Try a 3/8-16 bolt about an 1 in length, with a flat & split lock.
If you still have the old pump, can get the bolt from it.
RBob.
Old Jun 4, 2010 | 03:25 PM
norcalz28's Avatar
Makes perfect sense, fluid seeping past the threads. I'll get a bolt in there asap. Thanks!
Will
Infested
May 22, 2018 11:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
NBrehm
Aug 25, 2015 11:49 PM
mcquigg
Aug 13, 2015 02:26 PM
Kaweh
Aug 9, 2015 02:54 PM
