Rear brake question
Old Mar 5, 2001 | 06:51 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Rear brake question
Took off the rear tires saturday night while fixing the car to attempt to do the brakes and what do i find? Appears to me and a few others that i have 2-piston aluminum calipers....WTF? should my car have them? do i have(or should i have) single piston calipers up front? Has any GTA recieved 2-piston calipers in the rear brakes? any info would be nice
Originating member of the SJNEP Crew
Rice..It's whats for dinner!
All new projects put on hold till its fixed..whenever that is
Check out MyGTA
***AOL IM RiceEatinGTA***
Tony
Old Mar 5, 2001 | 11:14 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
As far as I know, all 3rd gens with rear disk brakes had single piston calipers. My stock IROCZ with a L98 engine has single piston calipers.
If you absolutely sure that you have dual pistons calipers, then I think that they are aftermarket.
I assume that you are NOT the original owner of this car, otherwise you would know that they are OE.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Mar 5, 2001 | 11:44 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I agree, they're 1-piston aluminum calipers. They have fins on the outside of the calipers and the rotors are almost 12" in diameter. Standard equipment for a GTA of that year.
Greg Westphal
'87 IROC 305TPI/A4
Old Mar 5, 2001 | 12:01 PM
fly89gta's Avatar
Car: 2018 Camaro SS
thats what i thought...these are 2 piston though....and unfortunatly i'm not original owner but i could always swing by his house to ask...i remember where he live...i think
Originating member of the SJNEP Crew "Welcome to Understated Sounds and Performance"
Check out MyGTA Nicknamed:The Big Red Machine
Tony
Check out www.transamgta.com
"What does not kill us only makes us stronger"
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
